Unwanted games installing without permission
I heard a lot of problems that are disturbing almost everyone. Very sorry :(. I think this support from here can help you, 1: Find the program that calls "CM Security, in the Play store .. 2: After you iinstall, launch for the first time, search menu scrol down to setting in CM security then click it, scrol down to the Advance Setting. click that, then Click "Heuriatic Engine " Active by cklicking. it may ask you -if the Heuriatic engine is Enabled ......... Just click Enable. Then scan your phone. Delete Whatever will appear to be vairus by clicking Resolve all. This is antivirus capable than any other, Avast, kespery, and other antvirus do not recognize virus that install programs without your permission.
*****And other Advice Do not Root Your divice
******unable to install application from unknown sources.In Setting
If problems are continuing please tell me !:)
Yes, it somehow helped. I am still observing it, though. It stopped the multiple unauthorized downloads but it didn't stop everything. I mean, I still get unauthorized download but it went down from, like, 10 downloads to just 1 or 2 in day. I was actually hoping that the anti-virus would prevent all these unauthorized downloads from happening.
Last winter, I had the same issues with something named SLOT MANIA which installed itself without being invited (nor announced). It was getting worse daily, also installing many other visible and hidden but sterile "apps". Tried all advices I met on the Web (including but failing to flash the ROM). Having other work on the agenda, I eventually gave up and purchased a new phone.
I had not thrown away my "broken" device, a rooted Elephone G1 (MTK6580-MTK6582 chipset).
Luckily coming across Elephone G1 Stock Firmware ROM (Flash File) yesterday morning and doing STRICTLY EXACTLY what they instruct to do to flash the ROM, EXCEPT ONE UNDOCUMENTED CHANGE IN STEP 9, within 15 minutes, at cost 0, after rebooting the phone I got it fresh, almost clean, as new.
Step 9 issue: the PC screen shows a selection window defaulting to "Download only". Select the next entry, "Flash Firmware", which completely overwrites the system.
Dirt left over: a few of those sterile invading dowloaded apps. Quickly gotten rid of with Play Store app "Root Uninstaller".
J.G.
MichaelCrusan
