Update question (rooted)
Ok was rooted using Exynos abuse.I unrooted then installed update now no root..What do i do now to re-root??
If memory serves correctly doesn't Exynos Abuse "patch" the security hole that this factory patch is meant to fix anyway?
Ok..If i don't want to reroot will this effect any future OTA updates?Will I still be able to update??
It shouldn't but I can not be positive
Yed this is why I have been recommending that people not update unless they v want to remain fully stock. The update is not worth losing root you can simply use the patch.
From my Galaxy Note 2 via Tapatalk
schoolregistrar001
