Upgrade from Note 5 to Note 10+...should I?
Not sure what kept you from upgrading before (what ever your reason it was valid for you, so.. no worries) I had the Note 5 64gb and it was an awesome device. Had the Notes since and they have been great. I am excited about the N10+ I got some quality time with one at my local BB and the Samsung In-store Rep. I would say if you can, go check them out and then decide what's best for you..
Cheers,
BR
*UPDATE* I put in my pre-order from Best Buy! Aren't you guys proud. Got $50 off, $150 Samsung store credit (which I'll probably get the earbuds), and I called Verizon and they waived the $40 upgrade fee. Now on to waiting for the 23rd!
Where is the fine print? Lol
$43 mf'n bucks, was totally not worth it to me. I will keep my note 5 as my car music phone. Then I won't need to worry about the 3.5mm jack. I can't completely rid myself of this guy. We've been through so much! It's like an ex I can't get rid of.
Your definitely going to be richer then most of us ...
Ok, this one does not say "up to"
Damn.... If that's accurate I should have traded an old LG phone. I traded the Pixel 3XL for 600 but getting 450 for a phone that's completely worthless might have been better.
I'm good with it though. What else does Verizon offer for pre-order?
going from a Note 5 to a Note 10 plus should be a bit of a back to the future type experience anyway
andiox
