- Mar 30, 2010
- 43
- 1
- 0
Seems like Helix is in an eternal force close and I can not do anything. How can I fix this without wiping the phone?
I do believe Helix 2 is meant for the Nexus? Hence, definitely less than appropriate.
Factory reset to rid you of it? Bummer![]()
How do I get Helix to start up on my Droid? I've installed it and uninstaleld a few times. Am I just dense - what am I doing wrong? I remember I had it on for a while before the 2.1 update. Now after updateing I can't get it to start. Any help would be appreicated.
OK - aprils fools! you got me. Now Really, what am I doing wrong?
I just told you............*sigh*
I suppose I have a simialar question....I installed and I have the 4 pinned locations but only have same 3 native screens....I am not seeing the additional that Helix is supposed to supply. Am I missing something?
Thanks
From the home screen, press menu, then go to configure, then the first option will be how many screens, select from there how many you want to have.
