USB C tethering Problem
firerescue32696
The Samsung Note 8 will not connect via USB C cable connection to your computer if you have "wifi" active on your phone. turn off wifi and reconnect the usb c cable and it will work.
It's not that it's on, it's that it's active. Tethering is just for mobile connections (whether via USB or WiFi, the phone cannot share a WiFi connection)
Actually, yes the phone can share its wifi connection.
I usually keep it off because wifi public wifi hotspots tend to be much slower than my LTE connection.
Actually, yes the phone can share its wifi connection....
Just wanted to let you know, in the list of forum topics, the preview of your pic shows the unedited password. Not sure how, but you might not want to use that one anywhere.
*EDIT* - I'm using the mobile AC forum app.
Thanks. I noticed that too.
I'm due to change passwords anyway.
mathewsjamie138
