USB-C to USB-A
The USB-C to USB-C cable that comes with the Note appears to be USB-C and not USB 3.1 which would have supported 10Gbps/100W. Only notable for folks that have a USB 3.1 port on their computer and transfer lots of data between the phone/computer.
I'm not sure I follow. You don't need to connect your phone to your computer to access onedrive.
Yes, I understand you don't have to connect with cable from phone to computer, but can share things, photo's ,documents using the note drive, from phone to computer.
But does the samsung flow app, do the same as using the one drive?
Just wondering which one works best or if they do the same thing?
Hope this makes sense.
Thanks
Thanks
They are not the same. Flow when connected to your computer opens a window on your computer where you can drag your files into our out of the phone, open the phone up, even use the apps on the phone from your computer like send messages and stuff.
Onedrive is just a cloud storage solution. Nothing more. Flow cannot replace OneDrive, and OneDrive cannot replace Flow. They are different things for different purposes.
Ok, thanks. That's what I wanted to know.
dumpsterrentals102
