USB Connection problem solved
barskin
710
25
18
A lot of us were having problems with the USB adapters no longer working after the next to the last update. I had one of the Samsung branded adapters (the one that came in the set with an SD card reader adapter) an a generic one that fit the propriatary connector, and they both stopped functioning unless I rebooted, and even that didn't guarantee it. But, I just tested it today to see if the latest update fixed the problem, and YES, it did. If you had that problem, try out your connector. It may be working fine now.
rosannejoy555
