USB Storage with SD Card Mounted
CraverEric
Active member
Sep 14, 2017
41
I use a USB storage device that connects to the phone just fine if the SD Card isn't mounted. If the SD card is mounted, the usb device doesn't connect. Can only 1 other storage device be connected at a time; or is this a bug that should be reported?
Report it as a finding anyway, the more feedback the more improvements:-)
williestringfield90
