USB tethering
I second this. I don't see an option either. Also, I can't even get the "SAMSUNG CDMA Technologies" to work (although this wasn't supposed to be used back in the instinct days).
FYI, there isn't a USB option (well there is, technically, its your en2 connection) but that doesn't matter. All you need to do is check the box for Internet Sharing, nothing else. Just realized what you all were asking. Just turn it on, the other setting is if you wanted to broadcast the internet connection to something else... like PS3 or something. Technically, you can do that. You would select From Ethernet (en2) to Airport or Ethernet or Bluetooth. Ethernet would be your best bet there if you wanted to do it. You still would have to manually set it up on the PS3, but you can google how to do that.
would someone be kind enough to explain how to tether a powerbook g4 to the Epic? I've tried with pdanet but nothing seems to work.
Haris18
