USB to Ethernet adapter and USB to go questions.
Ion_NotePro
15
Hi,
I would like to have an Ethernet connection to the note pro, preferably Gigabit. I have looked through the forum posts and have read some contradictory information about what really works.
What Ethernet adapter do you guys have working? With or without USB ports. For my particular need I only need Ethernet, but some may need to replace report.
I am also confused about usb-to-go. Does that mean I can connect a mini usb connector in the USB 3.0 port and use them? Sorry this is noobie question, but I do not have much experience with USB 3.0.
Thanks in advance to any/all help.
USBFirewire also has an adapter with two USB connectors. When I went to see them they told me they would design and build any cable you want.
