Using links2sd and still having market problem
montenell
55
Ive been using links2sd for a while with no problem but now if I try to download from market I get the insufficient memory and invalid package file errors, any advice on how to fix?
What does phone storage info say about remaining memory?
Link 2 sd does sometimes stop linking, in my case after a new ROM update, rewriting the script did not help. I ended up reinstalling the whole phone.
The error message I was getting indicated the partition is read only, which of course it was not.
did this just start out of the blue or after changing ROMs
are the apps you had linked before still linked
are you linking delvak cache [this is the first fix usually recommended or moving it to sd for non-link2sd users]
does your sd/ext match what you enter for link2sd?
Started out the blue, ironically I wiped my dalvik cache and my Rom became corrupt I ended up having to reflash so currently I'm not having the issue
easy fix. just open link2sd and link dalvic cache files. then you should be good to go.
MorriTinni
