Using nano sim with adapter??
well I am glad you never had a problem . but it only takes one time for the sim to slip out of the adapter and the adapter go past the prongs and the phone is most likely screwed because its nearly impossible to get it back out without damage. but im glad you've never had a problem hopefully you being so reliable you never will.
really don't know why you bothered posting as you added nothing helpful. other than to boast that you've never had a problem.
You are right. Adapters are horrible and could ruin a device.
Will I be able to use a nano sim with adapter in the Galaxy S5? I don't have a problem with other phones where you need a sim tool to pop out the tray. But, the S5 doesn't have a tray.
I use Media Devil that I found on Amazon. It works well with or without a tray. I go between my Note 3, M8 and Moto X with a nano sin.
SpinjamShopeepinjam
