Using NoLED instead of the LED
Snareman
2,412
84
48
One of my big frustrations (in my 1 day of ownership) is that I can't get Lightflow to work reliability. So I decided to go back and give NoLED a try. Not sure why I can't get LF to work consistently. Its completely random when it doesn't work and I have no idea why or when. NoLED seems to work well. I can tell what I have notifications for and then just a single tap on the screen and then hit the home button. Seems to work well so far. I'll give it a try for awhile and see how it works. You can set it to turn the screen off when the proximity sensor senses something, like your pocket and also when the phone is flipped over to help save the battery.
I am using NoLEd and it works great... The only issue that i have is the bug of the TalkBack that activates when i give NoLed accesability.....Seems like a Android bug...
koltyn
