UXToolkit HTC One M7 (Unlock bootloader, flash recovery, root, S-OFF)
Status
Not open for further replies.
Re: EZToolkit Adv: HTC One Toolkit [Unlock bootloader, flash recovery, root]
I think the second link I found is easier.
Thanks again, I tried your second link, but i get the message that "The best driver software for your device is already installed".
Could it be some issues with my paths (to fastboot.exe etc.) ... just a thought?
No, I think it might be HTC Sync. I suggest you uninstall it.
I'll try
Sendt fra min HTC One med Tapatalk
I get the same result as earlier - see below.
Just to be sure that i do it in the correct sequence:
1. I sign up for an HTCdev account (and nothing else)
2. I click on step 2. Get your Token ID
Code:
C:\Android\EZToolkit Advanced (M7-
'adb' is not recognized as an inte
operable program or batch file.
'fastboot' is not recognized as an
Press any key to continue . . .
... and after pressing enter:
Code:
Yep.
Thanks!
Benny3, your link is dead - file blocked.
i've just downloaded it - what shall I do with it?
It must be on your end, I have files downloaded from mediafire every day without any issues
Ok, thanks
I believe I have solved the problem. Re-Download the toolkit. I have added some stuff. See if it works now.
- - - Updated - - -
I got the error too.
I have to ask, Did you extract the contents from the toolkit zip? or are running it from the zip?
- - - Updated - - -
Now thats really odd...lol
Yeah, must be. I just tried again with same result :-(
- - - Updated - - -
I solved it I think. I think it was a mistake on my part. We'll see if my fix works. And as for your link, I think you're like me huh, I like to keep a backup of files that people make just in case they disappear or their links are broken and stuff like that :P
Yes, I extracted the files :)
I just downloaded the toolkit again and there's some progress. But I am stuck here:
Code:
C:\Android\EZToolkit Advanced (M7-M7WLS)>adb reboot bootloader
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
error: device unauthorized. Please check the confirmation dialog on your device.
C:\Android\EZToolkit Advanced (M7-M7WLS)>fastboot oem get_identifier_token
< waiting for device >
Code:
Make sure USB Debugging is on.
Open Settings> About> Software Information> More.
Then tap “Build number” seven times to enable Developer options. Finally you will see “You are now a developer!” message on the screen.
Go back to Settings menu and now you’ll be able to see “Developer options” there.
Tap it and turn on USB Debugging from the menu on the next screen.
After that, try again.
Code:
Keep the screen on and watch it and give it the permission when asked
Yup, t it works. I will post the Token ID om HTC dev now :-)
Nice! Just submit it and htc should send you the unlock code shortly.
- - - Updated - - -
The problem seemed to be that the adb.exe and fastboot.exe were missing in the main folder.
Status
ihtasham
