V20 + ZeroLemon 10,000 mAh battery = great combo
datum9
541
That's my next device. V20 + extended ZeroLemon battery.
they upped the capacity to 10,000 mAh. Or 3 times the size of the original, which is not adequate.
I had the zero lemon for my Note 2, battery easily lasted 3 days, didn't use it daily because it was heavy enough to pull down on my pants in a way I didn't like.
the real benefit of an extended battery is the case is larger, making it easier to hold.
Some phones are so slim and slippery, like you are holding an ice cube slightly larger than a credit card. In the original form, V20 is so slim and thin that it's hard to hold on to. ZL battery and its oversized case changes that.
Just wish the case had a kickstand.
Heck a 5000 maH battery with a symmetrical case and kickstand would do the trick for me.
hanspl
