Verizon Adv Calling Drop Calls on s6 Edge
ogdlow
48
SO.. I have activated the Advanced Calling on my S6 edge on verizon network and I keep getting poor service. I never have had any problems with coverage before, but once I activated this feature Boom.. It now sucks. Note- In order to use voice and data at the same time on the S6 you must activate this feature.
Anyone else experience this?
If you go from 4G to 3G the call will drop. I stopped using it because unless you live in a city with constant 4G coverage, you'll be experiencing a lot of dropped calls. Basically, regular calls use your CDMA radio on 1x. HD calling uses 4G instead of the CDMA radio so there's no way to swap the call onto the other radio in the event you wander into a 3G area.
The thing that makes me angery is that without Adv Calling you can not talk on the phone and sure the web at the same time..
joelkmason
