Verizon Incipico case and extended battery
jbomb11
Banned
Mar 22, 2010
606
13
2 questions here:
Can anyone tell me if the incipico case that Verizon sells in there store fits with the extended battery?
I picked up the extended battery yesterday and LOVE the extra juice but am VERY sad my body glove case wont fit with the bigger battery.
Any thoughts/recommendations on other cases?
Thanks!
The answer is yes and I'm pretty sure this has been discussed plenty of times on multiple posts.
So I apologize. I have been a part of forums for a while now and I feel there is some unspoken forum etiquette that I am not getting.
This reply is leaving me with that some nerd is being a giant synthetic kielbasa that is used to help solve feminine hygiene riddles and odor issues feeling.
Can someone help me?
2 questions here:
Thanks!
The case fits for the most part but there is a slight gap towards the bottom between the outer layer and silicone layer. It bugged me so I returned it.
I'm working on thinning out the inside of the bodyglove case to fit the extended battery better. It fits pretty snuggly with the lining removed but kinda hard to get the phone out after.
Reactions: jbomb11
Seidioonline has a case made for the extended battery.
I believe you can buy it on amazon as well.
Reactions: jbomb11
I use that case with the extended battery and there is a little bulge on the side where the soft case and hard case meet, very small almost not noticeable unless you look for it. Also I read somewhere that you can sand down the inside of the hard part or the case to make it fit better. I took my battery cover off and it fits perfectly that way for now.
I have no problems at all w/the Incipio Sacrylic and extended battery. Have had it for a month. The "gap" on the sides doesn't bother me or the phone. Try a search on my user name. I posted pictures in two threads before you joined the discussion.
witnessloc02
