Verizon Motorola Droid Turbo Battery %
fofjjsr
Android4life
Aug 18, 2011
1,026
7
Is there a way to show the battery % on the status bar next to the battery icon?
Re: Battery %
Not stock. It's in the command center widget though. You can get gsam from the play store which will show the % if you don't mind using an app for it.
Re: Battery %
Yup, you'll find Gsam universally accepted as the go-to battery app
Techview
