Verizon Motorola Droid Turbo Hey all help a moron out
-Myk-
154
This moron has a problem and a couple of questions.
Problem: I hid my Verizon contacts on my contact list. I need to get one of them back and can't find a way to do it. How would you say unhide the built in Verizon Voice mail contact.
Question:
Is there a way to add common system setting into the notification pull down menu? like being able to switch the Turbo from ring to silence?
Thanks for helping
Re: Hey all help a moron out
I am taking a guess here, but when you pull down on the notification shade, there should be a square at the upper right. Click that, and it should bring you to your quick toggles. Sound should be toward the bottom.
I did that, no sound option. I am looking for a way to add sound to it if possible.
Offhand, I am not sure. I don't think changes like that can be made on a stock device. The volume keys should silence the device.
fastest way that I know to go from ring to silent is long pressing the power button until the menu shows up
DeadlyDazza
