Verizon Note 3 on Metro???
From what I can tell, it might, but Metro PCS i think is going to drop CDMA in late 2015, which will then render the use of the Verizon Note 3 useless for 3G and voice.
I though Metro was GSM now, and you have to do something with band 4 on the note 3 from verizon to get it to work.
It should work in gsm mode. The Verizon Samsung Galaxy Note 3 is factory sim unlocked and is quad band gsm. You might not get all the bands though. You would need to set it to gsm mode.
Sent from my Verizon Samsung Galaxy Note 3
I was able to get 4glte on tmobile on my Verizon Samsung Galaxy Note 3 in lte mode, so you should be able get 4glte. It doesn't support utms 1700 so you would only get hspa+ in refarmed areas.
Vector
