Verizon Replacement for a Sticky Home Button?
Wildo6882
3,360
28
Anyone know if Verizon will replace an S3 with a sticky home button? It works, but sometimes it gives a half click that doesn't completely register and you have to push down harder. Seems like something that could be replaced with a CLNR, but just wondering if anyone had any luck with something like this. Thanks!
Not sure on this end but have you tried to call them? They should be able to tell you?
Good luck.
Sent from my Samsung Galaxy S III using Android Central Forums
Good luck.
Nah, haven't had a chance to. Just thought I'd throw it out to the AC community and see if anyone else had this issue and how it turned out. Didn't know if this alone would work to get a replacement. Thanks!
I know they would know better. It just popped up late last night. I was just wondering if anyone had any experience with it. That's all.
I'm having the same problem on my Verizon S3. It is only REALLY noticeable when there is no case on the device. Any fixes for this? Maybe a little rubbing alcohol will do the trick? Thanks guys
Sent from my SCH-I535 using Android Central Forums
My s3 replacement buttons were better but the AMOLED screen had many more dark blotches. Ymmv
