Verizon S3: Looking for rooted 4.3 flash?
Every time I turn off my screen tho, the percentage next to the battery icon disappears.
And when you look at the checkbox, is it still checked?
After loading the ROM did you perform a Factory Reset, wipe the system cache and wipe the Dalvik cache?
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk Pro
Really when it comes down to it I just want adblocker, no bloatware, and wireless tethering.
If that's all you want then just run Saferoot http://forum.xda-developers.com/showthread.php?t=2565758 and use FoxFi: https://forums.androidcentral.com/e...tore/apps/details?id=com.foxfi&token=hKgmIKRA (which doesn't even require root) and you don't have to worry about the answers to the rest of your questions.
Yes, and yes. the box is still checked. I found a solution tho.. I used the xposed module Gravitybox. It has a toggle for a battery percentage. So far it works great.
Sent from my SCH-I535 using Tapatalk
I updated to the latest 2.17.14 release from old&slow. I have had a problem with the camera. It has some overlay of squares. I'm not sure how to describe it so just have a look. Any ideas on why this could be happening?
When you loaded that did you wipe /system (along with /data and cache and Dalvik cache) prior to loading? If not you may want to try doing that and then reflashing the firmware.
I used an earlier release than what you listed (from late December IIRC) and haven't seen anything like you describe.
No I didn't wipe. I thought if the rooms are the sam. That I didn't need to. I'll try it all over again.
What procedure would you recommend I take now?
Perhaps I misunderstood you - did you just overwrite the earlier version of old&slow with a newer one, or did you update from 4.1.2 to old&slow?
If the latter, you can boot into your custom Recovery software (TWRP or CWM) and clear all of the ones I mentioned, then use Odin to reload the firmware.
Uh, why did you do that? Wasn't it working?
Anyway, I haven't messed with later versions - perhaps you should just reload the first version that you used?
Tbh, I didn't know I should do otherwise. I guess I just wanted all the new stuff, with theming and bug fixes. I'll just restart it all from scratch. I have TiBu, so it's no biggie.
I'm sorry if I missed this, but can I use this update to go from 4.1.2 without wiping all my data? I'd clear cache and dalvik but can I leave the rest of my stuff in place?
cpoole89
