Verizon Samsung Galaxy Note 3 - Sound issue with play music.
Nayhova1
5
Has anyone had any issues with the audio when using Google play music? I love the service and subscribed but I'm having an issue with the audio playing very low. I can toggle the EQ off and the sound goes up but I lose the EQ sound. If I power cycle the device the sound will go back to normal. Just wondering if anyone had any issue like this as well.
Sent from my SM-N900V using AC Forums mobile app
No issues with volume over BT or via the headphones.
My only issue is sometimes songs mysteriously go into "fast playback" mode and artists sound like chipmunks. But I think that has to do with LTE service.
Every Android phone I have ever had had this same issue. You can use the EQ but you cant turn most any slider to max or else the volume drops. I never could figure out why that happened and it only seemed to in Play. Either way its normal for the OS.
I don't think it is normal at all. I am having a new issue, just the past couple of days, and it is only when an AUX cable is plugged in. Doesn't do it over my BT ear buds.
If I have it plugged in via aux cable in my truck and skip to the next track, the volume goes down to where I can't hear anything. If I unplug, play through the speakers, then plug back in, it's fine until I skip to the next track. Driving me nuts.
- - - Updated - - -
I just got the note 3 and I have the same issue... Did you find a work around? Thanks
Britjetpilot
