Verizon Update G900VVRU1ANI2 Widget Problem
Scmm42
4
Verizon sent an OTA update today, less than a week after the last one.
After installing it, two of my home screen widgets went away: Feedly and Business calendar. The widgets are no longer to be found in the widget drawer. The apps themselves are still there and working.
Has anybody else seen this problem?
-- Scott
Welcome to Android Central! Did you go to Google Play and make sure those apps are fully updated? Are they preinstalled apps? If so, go to the App Manager, select the app, and see if you can uninstall updates. Then go to Google Play, select the app, and tap Update.
Another thing to try would be to boot into Recovery Mode and wipe the cache partition, which won't erase any personal data: Reset: Samsung Galaxy S 5 | T-Mobile Support
dealsshutter
