Verizon Upgrade with unlimited data
And you can't simply click next past that screen? That's what I did. Shrug.
I was able to click past that screen with the data plan options, but on the final page it showed only my talk/text plan info. The data plan line was missing. Confirmed it by checking the math in the order total. If you went past that point without the data plan showing..... I'd be very surprised if you still had unlimited data when you activate your S7.
Verizon explicitly said that unlimited data can keep unlimited when going to dpp, so long as you aren't on contract. If unlimited data dissappeared then contact Verizon to Reinstate it
If your doing the dpp and on unlimited these are the options you should see for data. Although it brings up other data packages you should have the option to select unlimited.
Annuji202
