- Apr 23, 2011
- 30,106
- 203
- 63
Please only post speed tests on XLTE.
If you have root, you can determine which band you are on. Band 4 is XLTE. Please see this thread :
http://forums.androidcentral.com/showthread.php?p=3248448
At least on my Verizon Samsung Galaxy Note 3, there isn't a way without root to see which band you are on, however, you can do speed tests at non peak times, any speed test over 72 mbps is xlte. You can use "open signal maps" from the play store to help you locate the nearest tower. It will tell you the direction of the signal.
Then use "advanced signal status" from the play store and look at the LTE rsrp signal, the lower the better, and about 55dbm is the lowest that I have seen. This is what I see at my desk at work :
Off peak outdoors(i was walking around to find optimal signal location) :
Indoors speed test at my desk at work (i work in a high rise among multiple high rises)
dpham00, Android Central Moderator
Sent from my Verizon Samsung Galaxy Note 3
