Unknown cause for beep sound.. which is driving me insane
Maxeffortdroid
Active member
Jan 19, 2022
44
Hello Everyone,
If someone can help me with this, I would be forever grateful and buy you a beer! I've tried everything and no one seems to be able to resolve it. Here's the context:
Problem: On most, but not all calls a tone beep occurs about every minute. The tone is loud and hurts my ears while doing (or receiving) a call, not to mention it's extremely annoying.
Phone & Carrier: Has occurred on both my old and new phone. Old phone was LG ThinQ 7 and new phone is Samsung S21 (128gig). I just got the new phone in December 2021. My carrier is Verizon and I'm on one of their regular 5G plans, not pre-paid.
Timeline: It's been happening for about 2 years. When I had my LG phone I could not resolve it even after speaking with both Verizon and LG techs on a conference call. I was hoping it would go away with my new phone since we could never resolve on my old LG, but sadly and maddingly it's still there! Argghh!
Details:
- With old LG phone nothing we did resolved it. Again, I worked with both Verizon and LG techs and no luck. We did everything including removing all apps and even factory resetting the phone.
- With the new S21 phone I worked with Verizon to test everything we could and nothing fixed it. They checked the signal strength and ran network tests. Finally it came down to 2 options: 1. safe mode or 2. factory reset. I had tried those before and they did not resolve it on the LG phone, but I tried again anyway. Strangely enough in trying safe mode for a couple days, I could not get the beeping to occur. So, Verizon thinks its an app on my phone, but I have no idea which one it would be and seems strange that the beeping still occurred on my LG when all the apps were removed with the factory reset. But maybe it's different with this phone. Anyway, I don't put games or garbage apps on my phone as I work in IT so I have at least some knowledge of the technical aspects and I'm very selective what I put on my phone. I pretty much use only well known apps, but there maybe some that don't fit that category. It's a real pain to try and go through removing apps one by one to see if I can find one that is causing the beeping, so I thought I'd post here and see if anyone has had this issue or knows of any apps that are known for causing beeping like this.
- I did not do any transfer from my old phone (like using Smart Switch, Verizon backup & restore, etc). I set up the new S21 from scratch and loaded & configured all the apps manually as well as copied all data/files over manually. I did this to make sure I didn't 'copy over' any issues that might be causing the beeping.
- The beeps occur whether on cell or wifi calling
- The old 'minute minder' that was on previous Samsung models does not come on this phone and I certainly have no loaded it - even if it's available.
- At my location I usually have either 5 bars of 4G or 3 bags of 5G, so that shouldn't be the problem and Verizon network techs confirmed my signal is good my tracking it for a few days.
- My wifi is high speed (225 MB/sec) so that's not the issue, and again, beeping occurs whether I'm on wifi or cell signal.
- My wife's iPhone13 does not have beeping at the same location.
So, the bottom line: It appears it must be some setting or perhaps an app. Does anyone have any ideas?
Thank you in advance for any help you can provide!
best regards,
Jamie
Honestly, I'm very surprised that no one else has encountered this issue, especially since I only use well known apps made by well know companies (i.e. Microsoft, Google, Yahoo, BitDefender, Amazon, Samsung, etc, et). This is so puzzling....
You would have to go back to in beginning where u mentioned safe mode it was ok and delete 2 apps at a time until it disappear, this will have to be on your end to perform
You might be able to narrow down the culprit app by looking at the app permissions menu and focusing on the ones that have Phone permission.
It would appear so... thanks for all the ideas man!
Ya...already did that. :P I guess it's take 5 apps off at a time or bite the bullet and do a factory reset..... the thing that unnerves me though is that I did a factory reset on my previous LG phone and it still beeped! So I'm leery that this phone will do the same... I guess I have to find out the hard way.... well thanks for the ideas. much appreciated. :)
Re: Unknown cause for beep sound.. which is driving me insane fixed!!!!
YOU TUBE! Disable it. I forced it to stop and then disabled it. No more beeps!
Since your LG beeped before and after a factory reset, and after the factory reset, from what I understand, you only had your necessary work apps on it, and the new phones doing the same thing, I would guess it's a work app particular to your job. That would also explain why nobody else can replicate the problem. Just another avenue that might help you.
Honestly that would drive me nuts... I don't know how you've put up with it as long as you have :eek:
Yes, it's driving me nuts. And yes, I've already tested my work apps - not the problem. Thanks though.
I removed BitDefender and it did no fix it.
I tried the You Tube trick and it did not fix the problem. sigh... thanks though.
Maxyguy666
