Vibration in battery saver mode?
thumper4524
12
Is there any way to use battery saver mode and still have the V40 vibrate on notifications, calls, etc? I can't find an exclusion to allow it, battery saver mode will be useless to me.
Nope. You can not use battery saver mode with vibration at the same time. That's part of the battery saving to disable vibration. It takes a decent amount of juice to spin the vibration motors so they're trying to save battery that way.
