Vibration problem...
Nuuq
357
My phone is not vibrating on sms or calls even though I have it turned on. Any ideas???
I think you also need to specify you want things to vibrate both in call settings and sms settings. You will find those behind the three little dots when you are looking at your dialer or your list of sms.
Try turning the settings on and off a few times. If that doesn't work, reboot. I had a similar problem yesterday with text messages and app alerts not kicking up sound notifications. First time that's happened. At first I thought it was related to Vonage's buggy Extensions app, which I was trying to use yesterday, but after seeing this thread, I wonder if something broader is causing this problem.
I have the same problem with my nexus 4 with LMY470 compilation. I think that it can by with 5.1 upgrade.
vigorific
