Voicemail update problems
I'm running an unmodified Evo Shift, and when I tried (repeatedly) to update my internal storage went from ~43 MB to ~29 MB. Now I'm down on internal mem and it's still hassling me to update the app.
Help?
I'm running stock ZVH and had the same issue (not enough space to update voicemail). Started deleting apps and trying the update after each delete. When I hit 62MB (out of 165MB) free internal storage the update finally completed.
Odd bug. I have the xtra50fix and my available internal is now 93MB and I have installed a couple of apps since the update. I wonder if the apk has some crazy internal space requirement or something. I'm not sure how I would go about checking into this.
What is the xtra50fix?
Apologies, I got confused for a moment.
What I meant was: The ROM I am using has the hack that moves the /dalvik-cache allocation, thus freeing up about 50MB internal.
xtr50fix, is also applied, but has more to do with keeping a signal.
Thanks for this, hopefully this helps me. I am running cm7, what rom are you on?
Same prob. here. I just didn't update and voice mail still works fine.Just got tired of messing with it!
Clear caches, should work then.
sent from my CM7/Reborn w/ 1 Gb internal storage Optimus S
Always happy to help, hit that thanks button if I did
bonbon
