Volume Auto-Adjusting Down
Dankees
Trusted Member
Mar 26, 2011
687
For some reason, when I try to raise my volume, the volume levels auto-adjust down to its lowest setting.
What is this? Please help!
Check all sound and volume settings to make sure you don't have any auto settings on.
Aside from vume settings try to check this area
Press up on the volume button jist two times on the phone. It shows you have sound off and on vibrate. Odd.
Press on Sound Mode where it says Vibrate. Should allow option to change to Sound.
Andacar
