Volume ringer wont go silent
HI guy's , I've encounter a problem
I'm on the Att pie version
When I select with the buttons to silent it only goes to vibrate but I can toggle silent on notifications panel toggle. Anyone else?
Same here, but I thought it was like that before the update.
I'm starting to think probably was , I'm usually on T-Mobile or Unlocked firmware and didn't encounter this . But as soon T-mobile or Unlocked firmware becomes available I'll go to those.
Yes, as soon as I swipe down after pressing volume. I can press (speaker) to silence my ringtone (ringtone)
Ok so few of us can't put ringer into silent mode with buttons only will go vibrate , now when I pull notifications panel down we can toggle silent from there.
I don't use silent much, I prefer Do Not Disturb and I use my volume buttons for media only. But I switched the volume buttons for the ringer and confirmed that it only goes down to vibrate and not silent.
I never would have even noticed this because I dont use the silent option ever. You're going to either hear vibration or a blast of Mariah Carey. Never silence. Lol
Here is a question for you. Do you have Vibrate enable when ring? Mine is off.
Vera135
