Volume Very Low with 4.2 update Help!
seattlezoid
8
After 4.2 update my volume is less than half it used to be. Netflix with sony headphones used to be ok but now I have to turn on sub-titles!
I was using the app Music Volume EQ to boost levels but that seems to have broken with 4.2
All my songs are half volume using app Android Music.
Anyone know of a fix or has this happend to you with the 4.2?
Seattlezoid
I haven't noticed any change in my volume on my nexus7 after the upgrade..... Mine seem normal.
UPDATE:
Well after using my N7 for a couple hours after update, I guess my volume "is what is was". I guess I was so used to the extra boost I got from
Music Volume EQ that I realized it was back to being normal. Hope the developer of MV EQ will update his fine app soon.
