warning camera fail
Ok let's see , keep me posted. Yeah it's a issue with that app
I will. I keep trying to check my spam folder as well to make sure that their e-mail didn't go to the spam folder. Hopefully, others have sent e-mails (to Snapchat) too.
This is happening to me to as well. I have found a temporary fix until Snapchat decides to acknowledge this problem. Uninstall Snapchat, install a previous version .apk file of the app instead. I have version 57.00.00 and it seems to be working fine. Turn auto-updates off for snapchat in the app store.
I have no idea how to roll back to the previous version.
Here is cgoulart35 post
I reported a bug to Snapchat weeks ago. Still no reply or any acknowledgement. I also tried updating my old Snapchat version to the new update on Google Play and it is still broken. Absolutely ridiculous. Very dissatisfied.
Also, download the old versions here:
https://snapchat.en.uptodown.com/android/versions
I have 10.57.0.0 (not beta). The newer ones don't work for me (same issue), but this one does. Feel free to try others and post on here.
Thanks!
I just decided to tweet out to Snapchat (and all official Snapchat related twitter handles) about the issue.
That's the way to do it ..
It truly seems to be the way to do it! I got a reply back pretty speedy. So I recommend everyone having this issue, to do the same! Because it's the only way they'll realize that many people are dealing with this and they'll roll out a update to fix the issue!
Because I told them what phone I had and that the software is up to date on the phone and that the Snapchat app is also up to date.
It seems that I am no longer having this issue after installing the recent software update for my S10+. After I installed the update, I updated it the Snapchat app and it seems to be fixed. Fingers crossed.
Glad to hear that , took awhile but hopefully stays that way.
I'm still having that issue with rear camera in Snapchat that just doesn't wanna focus. I've had about 2 updates on Snapchat since I filled out a Snapchat Support inquiry form.
I wish this problem was resolved for me. When I first open the camera up, it tries to focus and then crashes on me.
I've had to uninstall Snapchat.
MichaelCrusan
