Water damage sticker on note8
Jewels81
4,931
19
38
Is there a water damage sticker anywhere on note8 that says it's been water damaged or not? I'm asking cause I got the moisture detection notification on when I put a wet apply screen protector on and got a little bit of water in charging port. Got most of it out and guess notification will go away when dry. I've turned phone of a few times to try and get notification to go away but still there. I saw somewhere on Google that supposedly the sticker was inside the area where sim tray goes in but I didn't see it.
Edit: moisture detection notification just went away.
That moisture detection notification is there to let you know it's moist because the phone won't charge until dry.
Thanks but I know that lol. Is that a replacement of the water damage sticker then? I actually like the notification better tho.
It should go away om yours once it dries. Make sure you restart the phone.
On a side note, I adult had that message pop up on mine and it wasn't moist. It was a known issue Smasung ad used me of and I ended up getting a replacement phone (had that issue and a few other issues pop up recently).
Damn that sucks. Glad you got a replacement but at least in my case I was the one that caused the notification lol. It did go away eventually on its own. And did the the restart. But it went away before I did the restart tho
Sorry for the typos it auto corrected and I didn't see it lol.
Lol it's all good. I got what you were saying. It definitely happens. I don't know how many times I've had to edit my posts here lol😁
it's actually hard to see, you'll need good lighting and if you have a magnifying glass it will help too
Lmao I'm glad I had a magnifying glass cause I needed it to see it😁 My eyes definitely not like they used to be. Thanks a bunch.
gianfranco
