weid glitch when using flash
Chris Wayne2
65
Hi y'all, been using an AT&T's s5 for some days now and I came up to a very weird/annoying glitch with the phone: if I take pictures using flash the phone would suddenly turn off itself and it would reamin unable tu be turned on unless conected to charger or pc. I don't know is this is related to at&t or android 4.4.2 but do you guys have any suggestions of how to fix this?
It's probably related to a dead battery.
Thanks but no, problem solved: just deleted the camera app settings and info and restarted the phone.
BTW I don't know how'd you assume that since I've never mentioned that battery life was terrible.
Also, do you know how to delete a post?, I mean, now that my problem is solved.
For the moment, I will leave it open. This might help someone else in the future.
collingsmwale8
