Weird GS3 Problem
aeckman
Once every hour or so my phone would randomly turn off, I thought it was the battery so I replaced that. Now, while in use the screen will go fuzzy for a few seconds then shut down and not restart for a few minutes. The even more weird part is that when it restarts, I loose a ton of battery! It had 35% battery when it restarted, and upon powering it up it had 1% left. Its been factory restarted, and running the stock ROM.
I had a similar problem (although I never noticed the screen go fuzzy), and it turned out to be a bad SD card.
Welcome to the forums!
Even though this should have been covered by the reset, have you cleared cache in recovery?
Turn the phone off. Then hold the power button and volume up. Choose recovery mode (you scroll down the list with the volume keys). Let it do its thing and you should get another list, one will be for clearing the cache. Do that and then reboot thee phone.
Edit: I think I remembered that correctly
Sent from my Nexus S 4G using Tapatalk 4 Beta
Almost. You need to hold Volume up, Power and HOME. One you see the Samsung logo, release all three buttons. Then you'll see the recovery menu.
But a Factory Reset will clear cache, so I don't expect this to make any difference. It won't hurt to try, though.
Ah, it's different on my nexus s then. Lol I don't have to bother with the home button
shawnjosecrespo
