Weird lock screen while phone is charging
I also got this. Hit the three dots on top right and hit Mute for now. Went away and has not returned. I have not found the app that caused it but I do believe it was an update to weather. Cannot remove weather.
I love it when this forum provides an accurate answer. This stupid app was both driving me nuts AND was chewing up my battery. The good morning / good night screens started after the latest update to my S5, and I had no idea what it was or how to kill it. After seeing advice on the forum, I went into App Manager, disabled Peel, and answered "yes" when asked if I wanted to return to the factory default app. Problem solved. Now, to find a way to get Samsung / Google / whoever to stop including these asinine apps in their updates!!!
I've uninstalled peel remote too and still had the lock screen. Switched phone off and back on again and still there.
So pressed on the 3 dots and it said disable. Pressed these and it said I was disabling smart charge. Which is why I've not before.
I decided today to disable it as my phone has been on charge for about 15 hours and still only on 76%.
Stupid lock screen continuously displays ads.
I've also had an issue where I receive a text notification or WhatsApp and my phone notifies me every 30 seconds until read even when it's switched to silent. I've had to switch off all notifications.
This phone is driving me insane this week 😯
Still dont think it is Peel. I have tryed to replicate it getting rid of it by using the option that was present at the top left corner of the lock screen. But reinstalling Peel etc doesn´t make it come back..been looking thru all settings and nothing.
I don't have peel but I still got it. I was able to press "turn off" in the menu and it asked me if I really wanted to turn off "battery smart charge". It doesn't happen anymore. Mine had ads.
You don't have to disable Peel. If you go to your Application Manager, you can turn turn off permission.
Settings > Applications > Application Manager > More > Applications that can appear on top > Peel > off
The next time you open Peel, you will get a prompt to enable Peel on your security screen. Click cancel.
When I tried Settings > Applications > Application Manager > More > Applications that can appear on top > Peel > off .....
my settings only go to Application Manager and then lists all my Apps but no "More" or "Applications that can appear on top" so I get no further.
Any advice as this is locking my phone after charging. I'm a bit of a technophoebe too!
dgyfsdghhg
