Weird problem with and SD and battery drain, why is it happening?
  • Start date Start date
A
AC Question
Ok, so, first of all, the battery drains quite fast even in standby mode; 8 hours of standby = 10% of battery, and i merely use it for 15 minutes and it drained 5% of battery only for web-browsing. The battery was great at first, but after a couple of days of use i opened whatsapp and at that instant an app (i think it was gmail) started updating, which caused whatsapp to closed and a error to pop "The SD was removed". Now, the problem is... I don't have an SD card on my phone, but both WhatsApp and Telegram appears to be on an SD.
What might be the problem? Or am I being ignorant on something?
By the way, someone installed Marshmallow already? Is it worth it? I have everything download but I fear an error might occur and brick my phone.
Thanks for your time reading.
Re: Weird problem with and SD and battery drain
Welcome to the forums. I would try unmounting the card and see if that helps with your battery issues.
