Well, my 2.2 is working fine, no issues, anyone else?
Knock on wood......its been working just fine for me.
Had a few lag issues, but they seen to have straightened themselves out.
Looking good.
mine is also running perfect. literally no problems at all. bluetooth finally works right again, wifi finally works as it should, volume is louder, flash, better battery, music works,
I rooted a few hours after the update, removed all of the blaotware and my quadrant is 1523.
No problems for me so far. Of course it's only been a day and I haven't used every feature yet. I almost want to say the battery life has improved.
I spoke too soon. Looks like there's a 2.2 bug with the music player. It throws an "'unsupported file type'" with my music. A reboot fixes this, but it occurred nonetheless
No problems for me. My phone is much faster and battery life is the same or better. Music, texts, everything is working how I'd expect. Only thing I dislike is that they removed the Slide-To-Unlock Option, but that's not a bug.
Don't understand how so many people are having problems.
No problems here. Other than it took F...O...R...E...V...E...R to update on 3G since there's no Wi-fi here at work. Other than that though, I'm just loving me some Froyo!
No issues here, so far. I downloaded no lock from the market place to kill the slide lock screen. Music player plays fine, I like the gallery better, and finally I've had better wifi connectivity. Before the update I had issues with my X not connecting to my home wifi. So far wifi is steady.
I never rooted, and opted to stay with the factory setup.
:o I spoke too soon as well, lol.
When I got home to find my dx connecting great to my WiFi at first but soon found that it was just as quickly cutting off.Like hey its on Yay,, the dam its off fuk ...then hey its back .......etc.:eek:
I updated fine yesterday moring over WiFi's.It did not do that then.It was like stuck in a freakin loop .
I saw my incredible was staying connected .
I rebooted router, rebooted phone , battery pull , cache cleaned and factory reset and its working where I am now :) Has been for 4 hrs, so I think its fixed , know for sure when I get home if its not I will be pissed , lol :p
Mine runs perfectly. No problems and faster then ever =] music is louder battery is better great build here. Quadrant score of 1432. Not rooted.
My X runs great. Just one small problem. Battery deplets much faster than when I had 2.1. I have not rooted my phone or added any leaked software. I just don't know why. I have been using Avanced Task Killer thinking that might help but it has not. Any suggestions would be helpful. Thanks
I'm still on the leaked 2.2, with an updated build.prop, NO ISSUES at all.
Device runs perfect for me so I have no reason to go to the official.
I unplugged my device at about 5pm yesterday, here it is at 10am the next day and I am only at 90%, this is with browsing a few sites, sending some text messages, 2 phone calls and listening to a VM. :D
The OTA worked perfectly and went very quick and I have had NO problems since. Only improved performance!
Screen movement is snappier
settings, photos, apps and music transferred just fine
Music player works
Basically, this was a huge improvement for my X and I too am a little baffled by the disappointment and problems people are seeing.
Updated and is really good. I am so happy right now. My X is a lean, mean, fightin' machine.
anyone ran quadrant since froyo update?
ranging between 1430-1450.
Editing to add:
So far so good. Running unrooted, with LauncherPro+. I don't use a task killer, just go into the Running Applications screen every now and then to shut down the stock widgets and whatnot. I haven't played around with wifi yet so I'll report back on that once I get home tonight. I'm hoping they fixed the issue where you turn wifi on with a widget but still have to go into Wifi settings to get it to connect.
My app drawer no longer lags as I scroll through for the first time. Everything else seems smooth as silk at this point. I haven't put in enough usage yet to comment on battery life, but so far it seems like it actually might be drinking a little more juice than before.
Overall, I'm quite happy with Froyo.
The countdown to Gingerbread begins!
No problems here and my X went through alot today. SBF 2.1 Flash. Reinstall Everything, Official Froyo install, and rooted in less than 30 mins. But all is well. Not seeing any of the problems others are.
Been on the phone all day, numerous text messages, 4-5 emails, web browsing all during lunch and later in the day. I am at 80% battery life. Very happy.
One reboot
About eight hours after the OTA update, and during a phone call, the dial screen locked up and the phone rebooted itself.
Other than that one incident, the phone has been hammered hard with use and no other problems have been experienced.
vickyy
