I spoke with a rep at Motorola and they seemed to be unaware of a specific case yet. They are supposedly looking into it and will email me when they have one available.
Good to know that the silicone case works too. who makes the silicone skin you are using? I'll update the original post to show what cases work with the car dock mod.
Quadcam.
I got the bbrocketfish and works great. Just shave off that little nub on the back of the car dock and it fits like it was made for it. By far the best case I found so far and looks great inside the dock.
I just put a quick video shwoing how well the Rocketfish case fits into the car dock now. Unfortunately, I was trying to take the video with my storm1 but the phone kept rebooting on me about 10 seconds into the video.....
so, I had to shoot the video with the DX and just showed an empty case fitting into the car dock. Also, you'll notice, I mounted my car dock to my microwave to shoot the video. lol
YouTube - Using Droid X car dock with a case
Does the car dock only adhere/stick to a window? Or does it stick to, say, the dash as well?
I have the leather kickstand case from Verizon and I may pickup the car dock and shave off that nub...maybe it'll fit. Opinions?
The car dock comes with an adhesive-backed disc that you can mount on your dash, to which the suction cup mount sticks.Does the car dock only adhere/stick to a window? Or does it stick to, say, the dash as well?
If it fits in the car dock, would it also then fit in the home/desktop dock?
I also have a Zagg invisibleSHIELD for my DX but I am reluctant to install it since it seems to be something that requires painstaking care and dexterity; these are areas in which I am personally lacking.![]()
someone has already made it fit with the car dock, by removing a tab of plastic..
so since the phone is the same size, the "slot" part of the docks is going to be the same size, I would think if it fits the car dock, then it should also fit the home dock.
but i don't have a case yet to test it. (probably only a thinner silicone type of case would work)
I'm using my car dock with a Garmin sandbag (for my Nuvi) on my dash, that way when not in use I just put it under the seat. The ball on the Garmin sandbag fits the collar/socket on the Droid X's car dock very well.
