What do you want in Android KitKat?
Re: What do you want in Key Lime Pie?
"With Android Beam on Jelly Bean you can now easily share your photos and videos with just a simple tap, in addition to sharing contacts, web pages, YouTube videos, directions, and apps. Just touch two NFC-enabled Android devices back-to-back, then tap to beam whatever's on the screen to your friend."
Sending photos and video over Android Beam in Jelly Bean - YouTube
Cool... Does it work with the case on?
Some crappy NFC transfer that's failed the handful of times I attempted it.
what failed for you? there is a misconception with how android beam works.
developer has to implement Android beam feature to their app to transfer content of an app to other device or it will just open the app on the other device.
-I would like to have proper toggles in the notification pull down menu
-I would like to control the vibration in ONE place so i dont need to enter ALL apps and turn it of (But the possibility to turn on/off vibration in every app and the main vibration control in settings would turn on and off all vibration)
-I would like to be able to control the volume of the ringtone and notification separately (Now my phone rings freaking loud but my notification is very low)
-I would like to have the opportunity to make different sound profiles
-Possibility to make a "backup" in play store for what apps to be installed after factory reset (the most important apps) (Yes, titanium backup and other exist, but would like to have a stock built in function)
-LED control built in the OS (With different colors)
-As SHADMOS said: "Swiping notification marks email as read."
-Better battery
-Unified notification settings, including global streaming/polling setting option
-Project Laxative
-More robust camera settings and post processing options
-CONSISTENT BACK BUTTON
-Profiles (Work, Regular, Night)
-Further advance notification options (Delete emails from pull down bar, reply button opens pop up window, not full app, etc.)
A Where's My Droid / Android Lost / Where's My iPhone type of service built into the stock OS. This really should have been part of ICS, but JB the latest. Embarrassing that it's not there now, IMO
Cool whip.
- Can't move items from one folder to another without connecting the phone to a PC. I downloaded photos which i want to move to my camera folder, but they're stuck in the downloads folder until i move it manually in PC.
Try a file manager app. One of the best parts of Android as far as I'm concerned.
The ability to respond to text messages from the notification pane.
Sent from my HTC One S using Android Central Forums
I want Chrome to support plug-ins.
add seconds to clock
add clipboard viewer / editor
screen rotate 360 vice 270
fix nfc
fix otg
macro on camera
stabilized camera
Since this is general topic I wanted to post this in the popular forum which is Nexus 4. So, what do you want in KLP?
-Notification settings
Android has the most sophisticated Notification and yet it doesn't have a notification settings? so far just enable/disable Notification??
these are my wish list
Let customize volume level and ringtone based on apps.
Let customize LED based on apps. just like LED flow and move LED settings to notification rather than display.
Let customize vibration based on app.
Set notification to standard/low priority/disable based on apps. right now its just enable/disable.
Option in App info like "Disable Notification" to "Kill the app when closed"
Option in App info like "Disable Notification" to "Dont start App automatically"
See Notification from lock screen(PIN,Pattern and Password) and make it an option in settings.
-Lockscreen
authorize apps I choose to be access with out unlocking the phone.
-Project butter 2
-UI consistency
still lot to improve on UI
-Parental control.
improve and add multiuser/parental control to phones
-Backup/restore home screen and Application data to Google drive and restore to any device.
-Bed time mode. enable/disable notification at a period of time in a day.
-release the messaging app in play store just like calendar & sound search. integrate Gtalk/Google voice/Google+ messenger
-remote wipe/locate(find my phone) and manage device from play.google.com
POST YOUR WISHLIST!!!!!!
I want analog support because i dont want to root just to use a ps3 or 360 controller with analog
when is the approximate time that key lime pie is supposed to come out?
cinemacritic
