What Is The Best Battery % Indicator On the Market?
I use the SystemPanel app. The free version lets you view the battery percentage, but if you buy it, you can actively monitor what all is using your battery and it graphs out your battery life over time. Extremely useful and I highly recommend it. It also offers a lot more info besides battery related stuff.
I use the battery indicator in the simi clock widget. Just another great thing about that widget. It gives you another row for apps on your homescreen than the stock Htc clock...easy weather refresh...launcher for anywhere from 1-20 apps (or even a simi folder which is a whole other topic of discussion) slick look...can backup your config/settings...and
I am using the Battery Status app from Modded Logic and it works great!
Now, how do I REMOVE the stock battery icon on the RIGHT side?
crayzeefoo
