What is the best theme on the Note 5?
Can someone help me out? Im using Nova Launcher and the blak UI from the theme store. I'm not sure how to use the icons that the blak UI shows. Thanks in advance.
1586.jpg1586.jpgDoes anybody know how to change the color of the notification color from gray to combine it in with theme? When I updated to mm it put like a tool bar at top of my screen.Wifes phone stayed the same need help plz. The black writing was a arrow pointing the gray its hard to see because my wallpaper is camo. I would like to get rid of the bar like it was before the update. Thanks in advance
I've been using High Tech for awhile. It's pretty good. I also like the Sci-Fi theme.
I'm using that theme also. I like themes where they place the apps icon onto a special background so that the problem where the inconsistent app sized aren't as visible.
the blak UI icons won't work in Nova launcher only TouchWiz. The only TouchWiz icons that appear with Nova Launcher in use is the lock screen.
Right Here Please make Sure you read instructions if not rooted: [Themes] Samsung Galaxy Universal Theme Par
Best themes not on the market.....:cool:
Really like this rose gold theme from the samsung store.
Re: What is the best theme on the Note 5
Ok now everyone imagine a theme like ios yes i said it iphone on the note 5. I overheard someone saying how galaxies are complex and not user friendly. I almost laughed out loud. But is there a theme that can make the note 5 exactly like the iphone imagine that. Or if there is a way let me know
I know this is a REALLY late reply and you might have already found the theme, but search for "Santana 4.0" (by Felipe Leite) in the theme store, best iOS like theme I could find! I use the "Santana 4.0 Dark" theme on my Note 5.
Also saves battery because it's not using pixels to light up the screen.
Posted via my Galaxy Note 5
"[aire] sd_Black" is also a good theme to check out for battery saving. Its like "Weyo" but with more colors.
benjifred645
