What is your data speed on 3g?
The internet always seems fast though so I haven't really worried about speeds too much and only tested because of this thread.
I was thinking the same thing....everything loads fast on the phone, so I wasn't very concerned with the transfer speed. When I start tethering, my feelings may change.
I get around 1 mb/s to 1.2 mb/s down on 3g everytime i test. Upload is around .60 mb/s
I dont have 4g
before doing the ##DATA# reset i was getting 130 kb/s, that sucked bad.
I was getting horrible 3G speed and I reset the provisioning on my phone and went from 200k to 1.2mbps.
You'll need your MSL to do it, it's almost like re-activating your phone.
Do you mean it makes you start over from scratch as in erasing all my apps and home screen etc? Also where did you find reset? I see a bunch of stuff under ##data#
yes erases everything back to stock. and this reset is found in ##RTM# its the 2nd option reset you need your MSL to do this.
Jackwills2567
