What is Your Go-To Weather/Clock Home Screen Widget?
Are these meetings in your calendar? If so you can just use the Meetings feature of the Assist app to automatically mute when you are in a meeting. It can also be set to allow favorite contacts to ring through if you want, so if a family member calls in an emergency it will still ring the phone, but all other calls will not ring.
I have tried to adapt to using the Assist feature, but I just can't get comfortable with it. Call me old school, but I prefer to mute my phone manually (although I am learning to love the Do Not Disturb in HD Widgets). Thanks for posting though as I'm sure someone who doesn't know about that feature of Moto Assist will find it useful!
I just use the regular command center
Thanks. As many times as this has come up, this is the first solution I've seen (I must have missed this being correctly addressed elsewhere in the forum). I actually switched to the default launcher from Nova to test it, and "yep" that works.
No, I missed it also. :D I just decided I'd have to live with it. I took it off using the technique provided, but then put it back since I didn't gain that much space.
edison
Okay, changed my home screen. Still using Fancy Widgets.
One More Clock is my go to widget. I like simple look, though its "tap" features give me plenty of options.
Click, Click, boom.
shaik
