What launcher and theme do you use on your LG G3?
I like the default launcher aswell its just it feels like it stutters quite a bit. I like the speed of the transitions and scroll speed on Nova Prime as i use "lightning fast" for everything. If LG updates their launcher to be more smooth then ill gladly give it another try.
I actually switched to Nova Prime this morning when I discovered I couldn't resize a widget with the stock launcher. I've gotten spoiled since I used Nova Prime on my Nexus 5. The stock launcher is still a fine choice, however. Glad we have customization choices. Much better than the fruit company's devices. ;)
I love the stock launcher. You can customize the icons. It just works.
Posted via LG G3.
This is why I'm using Nova Prime, resizing of widgets. Plus you get different swipe animations and I'm so used to the swipe gestures (Been using Nova for a long time). Currently using it with Cryten icon set.
I have nova prime but I dont know if it me but everytime a use nova on all my divices at first is pretty fast and smooth but after a while it starts getting slower and if you uninstall it and install it back, it'll be fast again only for a certain time. I am sticking with the stock launcher now. It has everything i need and it doesnt get slow.. :)
LG G3
My stock launcher feels very slow compared to nova prime. I guess it's all based on what you prefer though
LG G3
I haven't noticed that with Nova Prime, but I'd suggest clearing the app's cache in Application manager and see if that helps.
Cleaning cache it means going back to the beginning. I get that. What i mean is that nova is pretty fast at first but after using it 3 months straight without changing your homescreen everyday you will feel nova is not as fast as when you installed it the first day. If i clean my cache again it will feel awesome again overall nova is the best launcher in rhe market. I just like the g3 stock for now, i've been using the stock for 2 months now and it feels as fast as the first day. My only complain is the lockscreen animation when you unlock your phone, it gets lag a bit sometimes and other than that perfect.
Sent from my LG-F400S using Tapatalk
affansahab2021
