cbreze
- May 30, 2011
- 2,881
- 88
- 48
Re: What the heck is "Weather Daemon?"
This is also what I have always done and get an update every 2 hours almost zero battery use. Disabling location is what seems to do the trick. If your in your city all day long there is no need for it anyway. I notice GPS is my biggest battery sucker.I'm using Weather & Click widget and it's great as usual, I've been using it for about 2 years now and it's great.
The key in most, if not all Weather widgets is to set it with specific Cities, and prevent using the Detect my location and GPS options, if you set your specific city it practically doesn't use any battery as it will be updating just at your specific Update Intervals.
So my advice is that if you want to keep using the stock weather widget, just go to settings and disable all GPS and Detect Location settings and set your city or cities manually, besides the obvious battery savings there you may also begin to use your Location with the Quick toggles and turn it on only when you really need it.
