What would be your 'Perfect' Android phone?
5.5in screen
Minimal bezel
Slight curve like LG G4
6mm thick
2 day battery under heavy use - removable
256gb memory expandable
Dual sim 5G
3Ghz Octacore
6gb ram
1g graphics
20mp cam
1w+1w Stereo speakers
Wolfson module
Wacom digitizer
Stylus
FM Radio signal sender
Sent from my LG-H818 using Tapatalk
Nexus Note:
-5.7 inch 2560x1440 Super AMOLED display
-Snapdragon 820
-4GB LPDDR4 RAM
-64-128GB in-built storage
-microSD card support
-Dual Front Facing Speakers
-21MP Camera with, OIS, LED Flash, Laser Autofocus, f/1.8 aperture
-8MP Front Facing Camera
-LED Notification Light
-USB 3.1 Type-C with Quick Charge
-One piece alloy frame and sides with poly-carbonate removable back (with lots of color and texture options)
-3,500mAh removable battery
-Qi wireless charging with fast charging, build into every removable back that is shipped with all phones (no separate accessory **** that's a different thickness back, this totally screws people who want to put a case on the phone cause case manufactures don't want to make cases for the different size accessory backs, I could care less if the phone is a little thicker, and for those who want a super thin phone there are already lots of other options out there to chose from so look somewhere else)
-Fingerprint Scanner, one touch
-Digitizer and Stylus Pen
-Dimensions about: 153.5 x 78.6 x 8.8 mm
I am in dire need to have a basic feature in android platform. That is to allow a OS level feature to undo any editing change.
Suppose you have written a long note and you just selected all the text for sake of copy paste as backup and accidently you hit any keyboard character or pressed paste button by mistake.. Result you lost all the note and annoyingly you cannot get that text back. On iphone you can get that by shaking the phone left and right which allow undo action.
When we will get that feature in android. Than can be in context menu which comes on long press to avoid imitating iphone as well patent wars.
Mine would be ..
Metal body
5.7 in display thin bezels
Front facing speakers
4000 mah battery
Wireless changing and type c
21 mp rear camera
13 front facing camera
Video in 4k
4 GB RAM
128 GB storage
Basically the Lumia 950 that dual boots Windows and Android! It's got all the best specs (maybe up it to a SD820), a removable 3000mAh battery, SD card slot, wireless charging, 2k screen, amazing camera, great looks... The list goes on and on
My perfect Android phone would not be Android hahaha. I am not a big fan of Android fans but Apple. You cannot just switch back to Android after using Apple.
Right, dream device.
Screen: 5" (border-less, 1920 x 1080)
Battery: 7,000mah
Camera: 16mp (F1.5) (OIS)
Storage: 32 GB + Micro SD
Processor: anything that keeps it smooth.
A droid a day keeps the Apple away
Dream device would be:
Screen: 4.8", small bezels, 1920x1080 resolution for better battery life than 1440p
Design: Metall back, no glass
Battery: 3000mah is enough I think if the phone handles battery like sony phones, (also thickness), REMOVABLE
Camera: S7 camera with 15mp than 12mp
Storage: Must have SD card slot, obviously the more the better
4GB RAM
OS: Stock android
4. 3 inch 1280*720 Amoled display
minimum 70% screen to body ratio
4gb ram Snapdragon 616 cpu
5000 mah battery with quick charge
64gb storage with sd card slot
Water and shatter proof
Android kitkat with system wide dark theme
Realistically such a phone would cost $300-400.
Basically what i want is a very compact phone with good specs and amazing battery life.
Although Xperia Compacts come close they are still bigger than what i want.
I would love to have the BlackBerry PRIV hardware with the Samsung processor and software features. Also, i would love the front facing camera to be at least 5 megapixels.
Start with the GS7 and make changes.
Keep the 5.1" display with LCD/LED with 600+ppi.
10GB RAM
128/256 GB storage
No microsd.
3600mAh battery
Increase to 16MP with same aperture as GS7.
Completely flush RFC.
10MP FFC.
Magnesium/aluminum sealed unbody and chassis.
Stereo speakers by Bose.
Fast wired/wireless charging.
Samsung Pay
No carrier bloat.
Fingerprint scanner.
drayb
