What's the difference between a 2.1 amp car charger and a 10W car charger?
Alber Abbas
whats the difference between a 2.1 amp car charger and a 10W car charger
I recently bought a 2.1 Amp car charger so i want to know will a 10W car charger will charge my lg optimus g F180S faster then a 2.1 Amp car charger.
Re: whats the difference between a 2.1 amp car charger and a 10W car charger
They are just the same. if you want faster than 2.1 amp you should get a 2.4 amp which is 12W. you can try the dual USB car charger from vority, you can search it at amazon. I'm using it so I recommend it.
Marabishi
